Date/Time: Thu, 23 Jan 2025 14:34:32 +0000
include columns with no data chart settings
View Count: 1055
[2018-11-29 14:53:50] |
User450179 - Posts: 105 |
Hi, As always I search the board before posting, but i am stumped. is there a way when using "include columns with no data " under chart settigns to have teh dots on the chart that are drawn when no trades either be black to blend in with the screen or turned off when no data? I do not liek seeing "marks " on my charts when nothign actually happened at this mooment in time. This actually is very noticeable in over night sessions. lots of long areas with white dashes wehre no data thank you JAY |
[2018-11-29 21:13:10] |
This is the option: Chart Settings: Do Not Draw Columns With No Data (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
