Date/Time: Thu, 23 Jan 2025 14:40:01 +0000
Chart won't stay maximized
View Count: 1475
[2018-11-29 14:29:15]
anpy - Posts: 35
Since I tried out "Window > Tile as grid horizontally" it's no longer possible to keep a chart permanently maximized (Window > Maximize). It returns to grid view every time I resize the main program window and on every SC restart. Already tried Window > Restore and Chart > Reset Child Windows (with current stable and pre-release).
Date Time Of Last Edit: 2018-11-29 14:38:59
[2018-11-29 16:18:29]
This must be caused by Windows 10. This is with certainty. Sierra Chart does not resize windows when you change the main program window. And when you restart Sierra Chart, the previous size and position of each chart is restored.
Date Time Of Last Edit: 2018-11-29 16:19:19
[2018-11-29 17:13:50]
anpy - Posts: 35
Thank you. Yes, when I restart SC it reliably restores window size and position. It's just that the main program window always shows multiple charts in grid view instead of one maximized chart. If I maximize a chart and then resize the program window manually (or restart SC) it switches back to grid view. Do I have to recreate the chart book from scratch or is where anything else I could try?
Date Time Of Last Edit: 2018-11-29 17:29:23
[2018-11-29 17:28:23]
anpy - Posts: 35
btw this does not happen when I create a new chart book (with multiple charts). Everything behaves as expected and I can resize the main window without it switching back to grid view. So not sure if the problem is really caused by Windows 10, it seems to be related to a particular chart book.
Date Time Of Last Edit: 2018-11-29 19:51:32
[2018-12-03 19:30:31]
Give us that Chartbook you have the issue with and we will test it. Here are instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2018-12-03 19:45:50]
anpy - Posts: 35
attached
Private File
[2018-12-03 20:26:47]
We cannot reproduce this using your Chartbook:
You also have some charts which do not have title bars and that could cause some odd behavior. This issue and any other unexpected behavior is all going to be related to the operating system. We cannot provide further help to you.
Date Time Of Last Edit: 2018-12-03 20:28:11
[2018-12-03 21:31:24]
anpy - Posts: 35
Thanks, that's exactly what it was. Just noticed that the problem only occurs when maximizing a chart that does not have a title bar. Unhiding the title bar solves the problem.
Date Time Of Last Edit: 2018-12-03 21:33:37
[2018-12-04 18:13:24]
ganz - Posts: 1048
https://blogs.windows.com/buildingapps/2018/12/04/announcing-open-source-of-wpf-windows-forms-and-winui-at-microsoft-connect-2018/
