Date/Time: Thu, 23 Jan 2025 14:35:06 +0000
[Programming Help] - alerts
View Count: 899
[2018-11-29 14:02:03] |
User635423 - Posts: 51 |
Hello, Is it possible to receive either an audio or visual alert for the Super Trend Stop study? I would like to be alerted when either the signal turns bullish or bearish. Is it possible to receive either an audio or visual alert for the Stochastic Momentum Indicator study? I would like to be alerted when either the signal turns bullish or bearish. If so, can you show me how to set these alerts. Thank you, |
[2018-11-30 17:28:59] |
Refer to: Study/Chart Alerts And Scanning We do not provide alert formula programming help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-30 17:35:09] |
Xfanman1 - Posts: 320 |
As SC Support pointed you to they have many useful examples in their excellent documentation. Try your hand at creating what you want and if run into a problem post it and many of us would be glad to help you out. It's better if you first attempt it yourself so you'll learn how to create and modify what you want. -- Scott |
[2018-11-30 17:48:26] |
Sawtooth - Posts: 4162 |
Here's an example for the Super Trend Stop study: super trend stop study For the Stochastic Momentum Indicator study, experiment with one of the CROSSOVER examples here, like #26: Study/Chart Alerts And Scanning: Alert Formula Examples |
