Date/Time: Thu, 23 Jan 2025 14:37:50 +0000
Chart Scaling in thousands
View Count: 859
[2018-11-28 16:16:54] |
User912279 - Posts: 102 |
Dear SierraCharts, To the best of my knowledge there is no way to scale a chart (like NVOL) in thousands instead of ones. Ie. instead of the usual hundreds of thousands that the NVOL has as value, to indicate 100k, 200k, 500k and so on. Would that be possible? Thank you! |
[2018-11-28 17:48:41] |
Yes it is possible by adjusting the Real-time and Historical Price Multipliers: Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) You will want to use .001 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
