Date/Time: Thu, 25 Apr 2024 00:48:57 +0000
LOHP and HOLP Indicators
View Count: 1653
[2018-11-28 15:37:36] |
User103693 - Posts: 2 |
Hi, does Sierra Chart offer these two indicators? HOLP - High Of Low Period LOHP - Low Of High Period They are J Carter indicators and I believe Sierra has them in it's general offering. HOLP flags when the lowest low bar's high is breached with a bar closing above the high of the low bar. In this reference drawing dis-regard the lower green circle. It's just a trailing stop point, not relevant to the indicator. The indicator should flag the bar that closed above the low bar's high. 2nd circle. LOHP is the opposite. LOLP flags when the highest bar's low is breached with a bar closing below the low of the highest bar within the period. Date Time Of Last Edit: 2018-11-28 17:54:47
Private File |
[2018-11-29 21:49:01] |
See if you can create this using this particular study: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-07 21:05:55] |
@sstfrederik - Posts: 403 |
Was recently asked about HOLP / LOHP. Made it available in the FreeBundle on my website. Enjoy. https://sst.frl/holp |
