Date/Time: Thu, 23 Jan 2025 14:43:35 +0000
send for analysis
View Count: 538
[2018-11-28 15:01:55] |
User19537 - Posts: 9 |
I sent a message log for analysis. I can log in and receive historical data, but it has trouble continuing.
[2018-11-28 17:39:53] |
We see you are connecting to TD Ameritrade. You need to set a Streamer Address Override as explained in the setup instructions here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions Also update to the current version following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-28 17:41:23
