Date/Time: Sun, 24 Nov 2024 13:35:38 +0000
Scale Question
View Count: 1311
[2013-11-05 17:48:42] |
infpz - Posts: 826 |
Is there a setting I can flip on so when the market makes a new high or low, the chart does not expand on its own? I would like to be able to use the Hand Tool to move the entire screen up or down to go find the current market, so interactive scale-locked will not work. Thanks, Patrick Z |
[2013-11-05 18:07:19] |
User14266 - Posts: 225 |
Right click on scale. Enable these two selections: Interactive Scale Range. Scale Range: Constant Range. Date Time Of Last Edit: 2013-11-05 18:07:39
[2013-11-05 18:27:15] |
M5amhan - Posts: 468 |
also if you want complete control over where the chart goes (nothing is automatic) you need to right click scale > click 'scale' and un check all the selections at the bottom (this is how i use it along with hand tool)
[2013-11-05 18:28:16] |
thanks everyone
[2013-11-05 19:57:06] |
Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
