Date/Time: Thu, 23 Jan 2025 14:43:39 +0000
Invalid Symbol?
View Count: 1104
[2018-11-27 20:27:31] |
User312841 - Posts: 26 |
I am trying to look at SPXL and SPXS, SPXL works fine, SPXS does not update dynamically (see pics). I tried reloading historical data. I am using Interactive Brokers DTS and both SPXL and SPXS are working and tradeable in TWS. Thanks |
Attachment Deleted. SPXL OK.JPG / V - Attached On 2018-11-27 20:14:53 UTC - Size: 40.75 KB - 280 views SPXS NOK.JPG / V - Attached On 2018-11-27 20:16:33 UTC - Size: 35.84 KB - 314 views |
[2018-11-27 22:22:59] |
Those symbols are incomplete and may not provide real-time data or recent historical Intraday data. Refer to the more complete symbol format here: Interactive Brokers Symbols: Stocks With Specified Exchange and Primary Exchange Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-27 22:24:00
