Date/Time: Thu, 23 Jan 2025 14:39:35 +0000
Pivot Points
View Count: 1126
[2018-11-27 05:15:18]
User798620 - Posts: 29
So i use Pivot points in my trading lots, and i like to use the Levels S1/R1 but for the current day and the past 2 days. my charts are typically smaller than 3 days time as i use a 15/30 min chart. im wondering if there is a way to have those 3 days all plotted on my current day? is this possible?
[2018-11-27 18:23:04]
You would need to create a chart that does have the full 3 days worth of data and then use the Study/Price Overlay study to place the Pivot Points subgraphs on the 15/30 minute chart.
The documentation for the Study/Price Overlay can be found here:
Study/Price Overlay Study
However, this is not really going to accomplish exactly what you want. There is not a way to do exactly what you want.
[2018-11-27 18:48:33]
Thanks i had already tried that one,and your right it was not exactly what i was looking for, im going to manually draw my levels each day i think, is there a way to extend past pivot lines maybe? and if so, extend them for 3 days only? brainstorm....
[2018-11-27 18:50:15]
Well you can certainly modify the study to meet your requirements. Refer to:
How to Build an Advanced Custom Study from Source Code
