Date/Time: Fri, 24 Jan 2025 00:48:48 +0000
custom intrday file import
View Count: 1350
[2018-11-26 18:37:38]
User12089 - Posts: 365
I have created a custom intraday file with the following format:
Date, Time, Open, High, Low, Close, Volume (Header is optional for Intraday data)
Text/CSV Data Format
see the attached screenshot Input Dataset pdf (note that the "ticks" are 1 per hour)
the import of such file into SC works fine. However if I try to create a custom drawn volume profile it works weird - ie too coarse grained (even though I did set the granularity of the profile to 1 tick) - ref the attached second screenshot
and btw I also get the same weird volume profile when the custom file is Daily (and has the same internal format as the one above)
so what is going on ?
Date Time Of Last Edit: 2018-11-26 19:05:52
attachmentinput dataset.pdf - Attached On 2018-11-26 18:33:09 UTC - Size: 43.68 KB - 348 views
attachmentCustom Profile.pdf - Attached On 2018-11-26 18:33:14 UTC - Size: 27.68 KB - 361 views
[2018-12-07 19:12:34]
We really need to get this data file from you and also the Chartbook with one single chart with the Volume by Price study on it and we will have a look at this.
You can attach these files by following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2018-12-16 11:37:43]
please find all requested files attached. the data in the attached custom CSV file is with hourly frequency. It imports correctly in SC. Moreover the bar volume study looks ok. However the custom volume profile draw study produces too coarse grained volume profile - too coarse grained for Hourly data that is - ref the attached chartbook and the screenshot
Date Time Of Last Edit: 2018-12-16 11:39:51
imagecustom-data-import-volume-profile.jpg / V - Attached On 2018-12-16 11:36:22 UTC - Size: 442.93 KB - 288 views
attachmentChartbookCUSTOM-DATA.Cht - Attached On 2018-12-16 11:36:52 UTC - Size: 40.04 KB - 293 views
Private File
[2018-12-18 18:46:37]
You need to change the Tick Size of the chart to match the smallest move of the data in your .csv file. In this particular case, you use 4 significant digits after the decimal place, so you would want to change your tick size to 0.0001.
Refer to the following for how to change the Tick Size for the Chart:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
Date Time Of Last Edit: 2018-12-18 18:48:29
