Date/Time: Wed, 30 Oct 2024 22:56:01 +0000
[User Discussion] - Crosshairs With Additional Horizontal Lines
View Count: 868
[2018-11-26 16:40:14]
User684064 - Posts: 1
Is it possible to fuse horizontal lines with the cross-hair cursor tool? For example, 1 line with an X tick distance above the cross-hair horizontal line and another line X tick distance below the cross-hair horizontal line. So essentially, a cross-hair of 4 lines (vertical, horizontal, line 1, line 2).
Thank you for your time,
IG
[2023-04-12 15:55:00]
User318521 - Posts: 47
any word on this
[2023-04-12 21:15:29]
John - SC Support - Posts: 35639
There was another user that asked for this a few weeks ago, and we pointed them to creating a customs study, which they did. If you can find the thread, you could ask them if they would share the study.
[2023-04-12 22:34:40]
andhow do i find that?
[2023-04-13 14:57:26]
There is a "Search" function for the Support Board, at the top of the board.
[2023-08-18 18:33:08]
ssangha84 - Posts: 121
Hello, I was wondering about this feature as well. I’ve tried every possible search and I can’t seem to find the thread you are talking about. Is there a simple way to do this?
