Date/Time: Thu, 23 Jan 2025 09:51:50 +0000
LOGIN FAILURE
View Count: 626
[2018-11-26 09:50:44] |
Ziklag - Posts: 73 |
please help: CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2018-11-26 12:35:55 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20181126-09:45:30.25845=1372=A373=1058=Sending Time Accuracy problem10=201 | 2018-11-26 12:35:55 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2018-11-26 12:35:55 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20181126-09:45:30.25845=1372=A373=1058=Sending Time Accuracy problem10=201 | 2018-11-26 12:35:55 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2018-11-26 12:35:55 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20181126-09:45:30.25858=Received unauthorized messages while not logged in10=225 | 2018-11-26 12:35:55 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2018-11-26 12:35:55 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20181126-09:45:30.25858=Received unauthorized messages while not logged in10=225 | 2018-11-26 12:35:55 * CTS FIX socket (1) | Socket gracefully closed by remote side. | 2018-11-26 12:35:55 |
[2018-11-26 15:38:59] |
Your computer's clock is not set accurately. Refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-26 16:25:21] |
The same settings have worked for me since quite long ago - what fails them now?
[2018-11-26 17:41:02] |
