Date/Time: Thu, 23 Jan 2025 09:26:38 +0000
Back test at SP500 tickers simultaneously
View Count: 561
[2018-11-25 22:18:34] |
User251809 - Posts: 1 |
Dear all, I would like to ask you a question regarding backtest. I have automated system which I would like to simultaneously backtest at all SP500 symbols with one common equity and maximum 4 different trades at once . I tried to check all tickers simultaneously with replay but SC froze and also this solution does not solve my request to test with one common equity and maximum 4 different trades at once. I also tried AutoTrade System Bar Based Backtest with Scan but this test one symbol after another not all toghether. Is there any way how to do it? Thank you |
[2018-11-26 21:01:01] |
No, there is not practical support for doing a replay with a huge number of symbols like this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-26 21:01:34
