Date/Time: Thu, 23 Jan 2025 09:46:06 +0000
DTS - SC Data - 1 minute and tick-data, can they coexist?
View Count: 667
[2018-11-25 18:35:51]
User365411 - Posts: 192
Using only one installation folder and connected to the "SC Data - All Services" is it possible to get 2 symbols with different "intraday data storage resolution"?
For example:
- EURUSD (forex spot) 1 minute data
- E6Z18 (euro CME future) 1 tick (or 1 second is ok too)
The purpose is to have both symbols in the same chartbook.
Sorry if the question is already been asked, but I searched in support board and in the help pages but find nothing.
Thank you
[2018-11-26 20:35:23]
No you need to use two separate instances of Sierra Chart for this.
This is explained more here:
Changing Chart Bars Period: Improving Performance of Loading Chart Data
