Date/Time: Sat, 01 Feb 2025 12:57:32 +0000
[User Discussion] - Trading System Based on Alert Condition - How to flatten at end of day
View Count: 1403
[2018-11-25 18:21:43]
sierrasimon - Posts: 51
Hi. As I understood, the trade management is working with the trade window, but the option under tab "A" to "flatten and cancel at set time" doesn't work. Why? Or is there an other posibility to flatten at end of day, by using a Trading System Based on Alert Condition? I looked everywhere and tried so much, but couldn't find an answer. Thanks.
Date Time Of Last Edit: 2018-11-25 18:24:14
[2019-07-13 14:12:52]
User235492 - Posts: 16
They have this in another post (this is what I'm using at this time):
Easy way to do it. Open the trade window on the chart that you trade from. I use the Control Bar button called ATW for this purpose. Then select the tab marked "A".
Choose Flatten Position and Cancel Orders from the Flatten and Cancel at Set Time Options dropdown box. Below that, add the Time at which you would like to flatten your position and cancel your orders.
Then select the And Disable Auto Trading at Time checkbox, which should stop your auto-trade system on your chart at the Time you selected.
Hope this helps.
