Date/Time: Thu, 23 Jan 2025 09:44:04 +0000
persistent vars confusion
View Count: 636
[2018-11-24 20:48:07] |
User525733 - Posts: 126 |
Hi, after going through the documentation i still have the following lingering Q: assume custom study A uses persistentint(1), can custom study B use the same key (setpersistentint(1)) without overwriting the value stored at key=1 by study A? please address this Q for the two cases below : 1) studies A and B are instances of the same study 2) studies A and B are different custom studies. thanks |
[2018-11-25 02:16:09] |
1. Yes. 2. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
