Date/Time: Thu, 23 Jan 2025 09:38:39 +0000
Different close prices on Daily and 60 min
View Count: 686
[2018-11-23 18:47:00] |
manfretto - Posts: 117 |
Hi, what can be a reason that Close on daily chart is different from 60 min one? I refer to Dax 201812-DTB 5 EUR on 29.10 for example. Daily Close: 11332 60 min Close: 11249 |
[2018-11-23 22:07:51] |
Refer to: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.6 - Differences Between Close Prices on Historical Daily Charts Compared to Intraday Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-24 11:13:57] |
So the option is to use non-standard 1440min intraday chart to show daily bars if anyone would like to see daily close equals to 60min close.
