Date/Time: Thu, 23 Jan 2025 09:51:13 +0000
Numbers bar tick limit
View Count: 1145
[2018-11-21 16:09:22] |
bitshine - Posts: 7 |
Is it possible to adjust the numbers bar text calculation to calculate ever 2-3 points instead of 0.5 as in the image below to make the data visible? https://i.imgur.com/C75u6Z2.png |
[2018-11-22 00:09:17] |
Follow the instructions in this section here for this: Numbers Bars: Adjusting Tick Size For Larger Increment Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
