Date/Time: Thu, 23 Jan 2025 09:37:14 +0000
Problems downloading historical intraday data for FDXMZ18
View Count: 712
[2018-11-21 14:27:26]
User864893 - Posts: 26
When i try to re-download historical data for FDXMZ18 i get this in the message log:
No historical data client is currently set to download historical Intraday data for FDXMZ18. | 2018-11-21 15:15:42
Did try it with V1842 and V1846 but no change. Also did a full reset on symbol database.
Redownload (Delete and Download Data) works for ESZ18.
Connected to GAIN-Demo.
[2018-11-21 17:34:31]
We do not observe any problem with this.
Do you see the symbol listed in Global Settings >>Symbol Settings? It will look like FDXM?##.
[2018-11-21 17:42:15]
yes its there.
Just tested on a different PC with 1842. Same error message even after Global Symbol Settings -> Update from Server.
Here the message log from the 2nd machine:
Reading Internal Order ID file. | 2018-11-21 18:48:50
Reading Trade Orders file. | 2018-11-21 18:48:51
Reading Trade Positions file. | 2018-11-21 18:48:51
Account Balance file. | 2018-11-21 18:48:51
Listening on UDP port 22903. | 2018-11-21 18:48:51
Software version: 1842 32-bit | 2018-11-21 18:48:51
Usage end date: 2019-11-15 | 2018-11-21 18:48:51
Enabled for: Advanced Features. | 2018-11-21 18:48:51
Enabled for: Advanced Features 2. | 2018-11-21 18:48:51
Enabled for: Sierra Chart Historical Data Service. | 2018-11-21 18:48:51
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-11-21 18:48:51
Current selected Data/Trading service: GAIN Capital/OEC | 2018-11-21 18:48:51
Chart Update Interval: 500 | 2018-11-21 18:48:51
Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2018-11-21 18:48:51
2018-11-21 18:48:51 Local computer time | 2018-11-21 18:48:51
2018-11-21 17:48:51 Local computer time in UTC | 2018-11-21 18:48:51
2018-11-21 18:48:51 Local computer time in SC Time Zone | 2018-11-21 18:48:51
2018-11-21 17:48:50 Server time in UTC | 2018-11-21 18:48:51
Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-11-21 18:48:51
Program path: C:\SC\SC-S5\ | 2018-11-21 18:48:51
Data Files path: C:\SC\SC-S5\Data\ | 2018-11-21 18:48:51
OS Version Number: 10.0 | 2018-11-21 18:48:51
Locale Setting: C | 2018-11-21 18:48:51
DLLs: Convergent.dll, Convergent_64.dll, SCPrivate.dll, Theoretical Average.dll, Theoretical Average_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2018-11-21 18:48:51
Created the DTC Protocol server. | 2018-11-21 18:48:51
DTC Protocol Server listening on port 11099. | 2018-11-21 18:48:51
Created the DTC Protocol historical data server. | 2018-11-21 18:48:51
HD Server Manager | Listening on port 11098 | 2018-11-21 18:48:51
Checking for new symbol settings for service code oec | 2018-11-21 18:48:51
HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-21 18:48:51
HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-11-21 18:48:51
Symbol settings are up-to-date for oec | 2018-11-21 18:48:52
Received 5 login tokens. | 2018-11-21 18:48:52
HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-11-21 18:48:53
HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-11-21 18:48:53
HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-11-21 18:48:54
HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-11-21 18:48:54
HTTPS login.sierrachart.com:443 (1) | Received socket Close event. | 2018-11-21 18:48:54
HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-21 18:48:54
HTTPS login.sierrachart.com:443 (1) | Closed. | 2018-11-21 18:48:54
HTTPS www.sierrachart.com:443 (1) | Creating socket. Using TLS 1.2. | 2018-11-21 18:48:54
HTTPS www.sierrachart.com:443 (1) | Connecting to IP: 204.15.192.108. | 2018-11-21 18:48:54
Received Date-time from server. Delay adjusted UTC Date-time: 2018-11-21 17:48:56.125. Round-trip delay: 00:00:00.236 | 2018-11-21 18:48:55
Computer time to server time difference: -00:00:01.167 | 2018-11-21 18:48:55
Error setting System Date-Time. Windows error code 1314: Dem Client fehlt ein erforderliches Recht. | 2018-11-21 18:48:55
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2018-11-21 18:48:57
GAIN Capital FIX Trading socket (3) | Creating socket. | 2018-11-21 18:48:57
GAIN Capital FIX Trading socket (3) | Connecting to IP: 64.94.37.238. | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (4) | Received socket Close event. | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (4) | Closed. | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-11-21 18:48:57
GAIN Capital FIX Trading: Sending the Logon message. | 2018-11-21 18:48:57
GAIN Capital FIX Trading | Connected to trading server. | 2018-11-21 18:48:57
GAIN Capital/OEC | Connecting to market data server sim.gainfutures.com:9301. | 2018-11-21 18:48:57
GAIN Capital FAST Data socket (2) | Creating socket. | 2018-11-21 18:48:57
GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.238. | 2018-11-21 18:48:57
GAIN Capital FAST Data: Sent the Hello message. | 2018-11-21 18:48:57
GAIN Capital FAST Data: Sent the Logon message. | 2018-11-21 18:48:57
GAIN Capital/OEC | Connected to data and trading server. | 2018-11-21 18:48:57
HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-11-21 18:48:59
HTTPS www.sierrachart.com:443 (5) | Received socket Close event. | 2018-11-21 18:48:59
HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-11-21 18:48:59
HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-21 18:48:59
HTTPS www.sierrachart.com:443 (5) | Closed. | 2018-11-21 18:48:59
HTTPS www.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-11-21 18:49:00
HTTPS www.sierrachart.com:443 (1) | Received socket Close event. | 2018-11-21 18:49:00
HTTPS www.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-11-21 18:49:00
HTTPS www.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-21 18:49:00
HTTPS www.sierrachart.com:443 (1) | Closed. | 2018-11-21 18:49:00
GAIN Capital/OEC | Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2018-11-21 18:49:03
FDXMZ18 5 Min #1 | Reloading chart. | 2018-11-21 18:49:05
GAIN Capital/OEC | Starting real-time market data updates for: FDXMZ18. ID: 1 | 2018-11-21 18:49:06
GAIN Capital/OEC | Requesting security definition data for: FDXMZ18. ID: 1 | 2018-11-21 18:49:06
No historical data client is currently set to download historical Intraday data for FDXMZ18. | 2018-11-21 18:49:06
Real-time Intraday chart data file updates started for FDXMZ18 | 2018-11-21 18:49:06
Intraday chart data file opened for FDXMZ18 | 2018-11-21 18:49:06
Opened cached Intraday file: C:\SC\SC-S5\Data\FDXMZ18.scid | 2018-11-21 18:49:09
No historical data client is currently set to download historical Intraday data for FDXMZ18. | 2018-11-21 18:49:30
Real-time Intraday chart data file updates started for FDXMZ18 | 2018-11-21 18:49:30
Intraday chart data file opened for FDXMZ18 | 2018-11-21 18:49:30
Opened cached Intraday file: C:\SC\SC-S5\Data\FDXMZ18.scid | 2018-11-21 18:49:36
Date Time Of Last Edit: 2018-11-21 17:52:33
imageSC-FDXM.png / V - Attached On 2018-11-21 17:41:37 UTC - Size: 202.91 KB - 264 views
[2018-11-22 00:37:41]
We have determined the problem and this is now resolved. When we were testing previously we were using a different EUREX symbol.
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
