Date/Time: Thu, 23 Jan 2025 09:45:35 +0000
Consolidated NBBO prices for Stocks/Options
View Count: 702
[2018-11-21 12:59:11] |
User754985 - Posts: 109 |
Is there a way to receive consolidated NBBO feed for stocks/options from SC real-time data services? Is there any other data service besides IB that provides this? |
[2018-11-21 23:54:43] |
This is supported only for stocks when using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-22 00:21:26] |
Ok. For a stock that trades on 6+ Exchanges what would SC's symbol be to receive a consolidated BBO feed (rather than from a particular exchange? |
[2018-11-26 18:04:28] |
There is nothing you need to do. You just use the standard stock symbol.
