Date/Time: Thu, 23 Jan 2025 09:31:31 +0000
Keyboard Shortcuts for Limit Order
View Count: 1299
[2018-11-21 12:26:26] |
User432142 - Posts: 44 |
Hello, is there anyway to assign keyboard shortcut for limit order and it will be executed where mouse pointer. l tried to assign but it worked as market order |
[2018-11-21 17:47:21] |
No, this is not supported. The closest available is what is documented here: Basic Trading and the Trade Window: Custom Trading Keyboard Shortcuts And: Chart Trading and the Chart DOM: Using the Chart DOM / Order Entry Ladder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-21 17:48:24
