Date/Time: Thu, 23 Jan 2025 09:47:03 +0000
Continuous session volume by price study?
View Count: 1052
[2018-11-21 10:17:35] |
User284663 - Posts: 44 |
Hello, is it possible to have the volume by price study set to display the profile from the present time to i.e. 6 hours into the past, and continually stream that as the profile?
[2018-11-21 16:32:54] |
John - SC Support - Posts: 37420 |
Yes, you need to set the Volume Graph Period Type to One Period at End of Fixed Time Length and then set the Time Period Type for 'Fixed Time' to Minutes and then set the Time Period Length for 'Fixed Time' to 360. Refer to the documentation here for this: Volume By Price Study: One Period at End of Fixed Time Length For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
