Date/Time: Thu, 23 Jan 2025 09:29:19 +0000
ZigZag Tool
View Count: 1322
[2018-11-21 08:26:09] |
nicktrader - Posts: 732 |
This tool is quite useful but how to handle if you like to change the color or width for the whole drawing (more than one line). In the first step I saved different options (TC1 to TC8). Each time the tool starts with TC1. How can I change from TC1 to TC2 or TC3 in one step? At the moment I change it from line to line. But this is very time-consuming. Is there an other way? |
[2018-11-21 16:33:08] |
John - SC Support - Posts: 37420 |
There is no way to change the configuration for all the lines at one time that are drawn with the Zig-Zag tool. This is because each section is really considered an individual line, you are just allowed to string them together using the tool. For an easy way to change the configuration for an existing drawing, refer to the following and the section below it: Chart Drawing Tools: Applying Predefined Tool Configuration to Existing Chart Drawing Using Chart Drawing Menu In order to select the tool and a configuration at the same time to ensure that you have what you want up front, refer to the following documentation: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
