Date/Time: Sun, 24 Nov 2024 12:01:14 +0000
Datafeed via SC vs Transact - how to subscribe
View Count: 1344
[2013-11-04 20:38:02] |
User33681 - Posts: 37 |
How does one go about subscribing to the SC datafeed vs Transact when their broker is Infinity Futures and the platform is SC? Is the SC datafeed live to all traders or is it still being tested by the 6 traders identified? |
[2013-11-05 01:42:25] |
You will need a direct paid account with Sierra Chart if you do not already have one: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html After that you need to follow the instructions here: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php The data feed is still being limited to just the 6 users at this time. It should be available to everyone else on November 5 or November 6, 2013. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
