Date/Time: Thu, 23 Jan 2025 09:47:40 +0000
How to go about adding things to Trading Window for Chart?
View Count: 584
[2018-11-21 03:43:08] |
User640689 - Posts: 5 |
Follow up to this discussion: Is it possible to make an non-market order type for ACSIL automated trading? Building from what I want to do mentioned in above post. I want to perhaps be able to open Trading Window for Chart, "CTRL+SHIFT+T", and perhaps do what I mentioned in the post linked above by making an order. But the order based on the logic and conditions I slightly mentioned in the post linked above. How would I go about adding say an order type, or perhaps a tab/view/section to the Chart trading Window from a study? Date Time Of Last Edit: 2018-11-21 03:43:36
[2018-11-22 09:02:47] |
Instead you need to use Control Bar buttons. Refer to: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
