Date/Time: Thu, 23 Jan 2025 09:25:05 +0000
Question
View Count: 679
[2018-11-21 01:55:09] |
Sierra Chart - Max - Posts: 5779 |
I have a client asking the following:
I want to place an order in the following manner. Lets say the CL market is at 56.70. I want to place an order to buy at 57.00 on a limit but only if the market goes to 57.20 first. If the market rallies to 57.20, then I would like to automatically have the order to buy at 57.00 go into the market. If that is filled I need an automatic order to go in with a profit target OCO a stop. Is this possible? Can he do that using Sierra Charts? Thanks, Sierra Chart Support |
[2018-11-21 03:49:36] |
Yes this is fully supported. This can be done by using the Triggered Limit order type: Order Types: Triggered Limit And then you will want to enable Attached Orders which will become active when that limit order becomes active itself: Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-21 03:50:12
