Date/Time: Thu, 23 Jan 2025 09:44:29 +0000
Market Mapping filter on Timeframe switch
View Count: 589
[2018-11-20 15:40:06]
User849476 - Posts: 17
Dear support Team,
Today i have 3 different charts where i draw my levels manually.
Each chart is dedicated to a timframe (weekly, daily, hourly).
Tomorrow, I would like to have only chart where i switch from a timeframe to another using the keyboard.
To make it less messy, is it possible when i map my market on a Daily Time frame for example, to have my daily levels appearing on the Daily and hourly and not on the Weekly ?
another exeample, lets say I map my levels on an hourly time frame, to have it only on the Hourly and not on the daily and Weekly time frame.
I would like to have my mapping cascading from the weekly down to the hourly but I don't want to have my lower timeframe mapping appearing on a higher timeframe.
I know it's possible on MT4 but I find SC is way better.
Thank you,
[2018-11-20 19:44:19]
We are not really understanding this clearly. You do have the ability to copy chart drawings from one chart to another. Refer to:
Copying Chart Drawings from Other Charts Automatically
It is not supported though to prevent a chart drawing from appearing based on the bar timeframe.
