Date/Time: Thu, 23 Jan 2025 09:30:15 +0000
adjust order marker length
View Count: 626
[2018-11-20 10:46:39] |
User169205 - Posts: 67 |
hello, were is the option to adjust the chart order markers ? thanks |
order markers.png / V - Attached On 2018-11-20 10:45:49 UTC - Size: 1.54 KB - 241 views |
[2018-11-20 19:18:48] |
Refer to the following and the two sections below it for aligning the Orders: Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu) And also the following and the two sections below it for what is displayed in the Orders: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ChartTradeSettings_DisplayDetailedOrderInformation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-21 10:23:49] |
great, thanks
