Date/Time: Sun, 24 Nov 2024 14:26:38 +0000
[User Discussion] - SILLY QUESTION - WILL YOU CREATE A STUDY - COUNT UP TIMER
View Count: 1340
[2013-11-04 16:47:39] |
User33681 - Posts: 37 |
Notice you have a countdown timer - will you consider reversing this to create a count-up timer?
[2013-11-04 17:07:16] |
We can do this if we have other requests for it. This is the first one.
[2013-11-15 16:09:12] |
hft168 - Posts: 31 |
I also wonder if there is any easy way to have a timer in the spreadsheet or somewhere in the trade window, that can modify a limit order with a time frame, which will cancel a limit order when a set time expires. Thanks. |
