Date/Time: Thu, 23 Jan 2025 09:43:39 +0000
Is it possible to make an non-market order type for ACSIL automated trading?
View Count: 1456
[2018-11-19 22:18:19] |
User640689 - Posts: 5 |
I'm trying to automate some of my trading. I want to be able to put a price, then trail a number of ticks above or below that price to execute under certain conditions. An example for buying would be: the market trails 9 ticks above the price I gave and then at some point the Ask volume is exactly zero and the bid volume is above zero. Here I will wait for the price to go down a few ticks, all the while the price being above the initial input price, to then buy at the given tick/price. I want to automate this but I am not sure how to go about it. thi si a learning project where I want to learn ACSIL. If I wasn't clear enough in my post here, please be patient as I trying to make myself clearer. Tank you. |
[2018-11-20 11:06:40] |
Yes this is certainly possible. Based on your conditions you just submit a nonmarket order at that time. Here is the documentation for performing trading from ACSIL: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
