Date/Time: Thu, 23 Jan 2025 09:28:17 +0000
quick question
View Count: 693
[2018-11-19 22:08:06]
User266786 - Posts: 7
Love the platform..been searching the boards looking for an answer.
Symbol $tnx.x
US 10 Yr Tsy Yield...what package do I need for real time data..is there a CFD alternative?
[2018-11-20 10:38:53]
There is no CFD for this and the symbol is $TNX. Here is the relevant documentation to access this data:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AccessCashIndexMarketData
[2018-11-20 12:53:50]
Ok well..It is $tnx.x through TD Ameritrade.
The problem is they dont have xbtusd-bmex in their symbol db. So I can get one or the other.
Use SC Data and have access to xbtusd-
or switch to TD Data & access $tnx.x
I'll live with it, Thanks
[2018-11-20 18:39:27]
We just need to add the crypto currency symbols to the Symbol Settings when using TD Ameritrade. We will do that.
[2018-11-21 01:56:09]
The symbol xbtusd-bmex worked for awhile but now its down again. Thanks for adding it.
[2018-11-21 03:23:06]
We are checking on this.
[2018-11-21 04:21:36]
All good, thanks
