Date/Time: Thu, 23 Jan 2025 09:51:26 +0000
Order entry...
View Count: 646
[2018-11-19 19:41:17] |
User629089 - Posts: 93 |
Hi, I'm using an OCO order type through SC's for order entry on the ES. If long, I would have a lmt order attached above the mkt and a stop order attached below. This would be an "all in at the same time" and "all out at the same time" approach. What if you wanted to get out of a partial qty of your whole position before the lmt order is hit (with a mkt order for example)? The problem is the qty for the lmt order above the mkt and stop order below the mkt remain the same as the original/entire position. Is there a way for this lmt/stop qty to be reduced to reflect the reduced order size after some of the postion was liquidated? I hope this makes sense. Thanks |
[2018-11-20 00:54:33] |
Yes. You need to use the Scale Out functionality: Attached Orders: Scaling Out Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
