Date/Time: Thu, 23 Jan 2025 09:47:44 +0000
Playback Issue
View Count: 602
[2018-11-19 17:24:54] |
User143052 - Posts: 34 |
When using playback and I go back to see a trade signal again the system doesn't pick up where it left off. I will be short 2 contracts in a trade and when I go back to see a recent signal again I am short a different number of contracts when it opens back up. If I am short 2 it will reopen with 4 or 5 etc.
[2018-11-19 18:37:49] |
This is definitively not supported and cannot be supported. Refer to: Replaying Charts: Replay and Trading You cannot expect the behavior which you want. You are going back in time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-19 18:38:33
