Date/Time: Thu, 23 Jan 2025 09:38:27 +0000
Open Chartbooks
View Count: 941
[2018-11-19 16:05:23] |
User333736 - Posts: 22 |
How many chartbooks can you have open and running at one time?
[2018-11-19 17:59:07] |
There is no limit. However, you may want to use this particular setting: General Settings Window: Destroy Chart Windows when Hidden (Global Settings >> General Settings >> GUI >> Application GUI) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-19 18:02:56
