Date/Time: Thu, 23 Jan 2025 09:35:38 +0000
Export bar data to text file only export 30 sec interval data
View Count: 696
[2018-11-19 16:02:14] |
User291336 - Posts: 4 |
I already try to redownload the data but i only can export the 30 sec interval data i dont understand why it show Requesting 1 Day of data at 30 secs with ending date-time at 2018-11-16 17:53:00 for HSI-201811-HKFE. PriceType: TRADES | 2018-11-19 17:10:04 i can export 5 sec and 1 sec without any issue for 30 minutes only |
[2018-11-19 18:42:47] |
This is a limitation of the data from Interactive Brokers. Follow the instructions here to get tick by tick data for the data prior to the most recent 15 minutes: Interactive Brokers Trading Service: Using Sierra Chart Historical Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-20 04:06:43] |
Sierra Chart - Max - Posts: 5779 |
From User: Halo, are there any function can let me extract the tick by tick historical data (over 15 minutes) from IB instead of download it from other source? From my testing, the reload function under Multicahrt can request for the tick by tick data from IB again Sierra Chart Support |
[2018-11-20 20:17:12] |
No, this is not supported.
