Date/Time: Thu, 23 Jan 2025 09:35:50 +0000
sound and color alert
View Count: 750
[2018-11-19 14:03:48] |
User635423 - Posts: 51 |
Hello, Can Sierra chart set sound alert when both stochastic on 1000 tick chart and 3000 tick chart hook/turn to same direction, and at the same time the candle color will change to blue (up) and yellow (down). Will this setting (sound, color) also work during replay simulation. Thanks, |
[2018-11-19 18:30:46] |
Yes this is supported. Refer to this page: Study/Chart Alerts And Scanning And: Study/Chart Alerts And Scanning: Referencing Studies on Other Charts You need to study the documentation fully on this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
