Date/Time: Thu, 23 Jan 2025 05:08:54 +0000
Windows error code 193:
View Count: 1146
[2018-11-19 06:03:11]
User316362 - Posts: 210
I've been using this dll for weeks (my dll). I tried recompiling, using different Sierra versions etc. But it just started today, Sunday evening. I see that others have been having this problem also in the past with other DLLs.
Any clues?
CreateStudyDLLModuleFunctionObject Error loading C:\SierraChart\Data\HamptonTrader.dll. Windows error code 193: %1 is not a valid Win32 application. | 2018-11-19 00:50:10
Date Time Of Last Edit: 2018-11-19 06:05:26
[2018-11-19 06:07:12]
Make sure you are running the 32-bit version of Sierra Chart because it looks like that DLL requires it. Refer to:
How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart
[2018-11-19 14:30:15]
I'm sure it's compiled at 32bit and I'm sure I'm running the 32 bit sierra version. I reverified
This started without me changing anything.
This is a deployed DLL.
One thing I did notice is that WIndows 10 pushed an update on 11-17.
I'll try some things on my end to see if I can pinpoint it.
Date Time Of Last Edit: 2018-11-19 14:40:32
[2018-11-19 14:51:53]
Update.... The DLL is 471 KB in size. I uploaded it and forced an update. The DLL shows up in the Data directory as a 0 bytes size file when deployed
could it be the Sierra update/deployment mechanism?
Date Time Of Last Edit: 2018-11-19 15:00:29
[2018-11-19 15:27:37]
OK, I deleted everything and removed the file from the update list. I then updated the file again and added the file name back into the DLL name for updating.
I forced an update and all is well now. How a zero file size got in the mix I haven't a clue.
Resolved.
