Date/Time: Thu, 23 Jan 2025 05:03:46 +0000
DOM Technical Problem
View Count: 700
[2018-11-16 19:03:25] |
User256769 - Posts: 1 |
I am using the trial period. But at the Dom Limit Buyers and Limit Sellers are not shown - there is one (1) (One Contract at each side). Is this only in the trial mode???? No Date for Limit Buyers and sellers to see. I have configurated all. Also was watching videos at YouTube). Also I dont know to show limit buyers and sellers in the Order Flow Chart (Number bar Charts), Thanks in advance for quick reply.
[2018-11-17 04:27:57] |
Tell us the symbol that you are using.
