Date/Time: Thu, 23 Jan 2025 05:14:11 +0000
Trade Activiy Log then Trades tab
View Count: 659
[2018-11-16 15:44:29] |
User297050 - Posts: 51 |
You had a great thing going for a couple of days then it changed. Under "Edit" and "Descending Order" not checked: For the 14th it showed the daily trades in order of execution for the day and running total was the total for the day. Then on the 15th it created a blank line and again showed the daily trades in order of execution with the running total giving the total for the day (15th). The 15th was on top so the current day's trades were shown at the top of the screen with the first trade of the day at the top. Now today it is going back to the old way and just adding the trades for the 16th to the bottom of the 15th. That was a genius way of doing it because it leaves a great history. Each day was shown with blank line between the days and all trades in order for the day with a running daily total. Please go back to that option as it was GREAT! |
[2018-11-16 17:32:36] |
Then on the 15th it created a blank line and again showed the daily trades in order of execution with the running total giving the total for the day (15th) This does not make sense. There should not be a blank line between days. Only a blank line between unique Symbol and Trade Account pairs.Now today it is going back to the old way and just adding the trades for the 16th to the bottom of the 15th. Yes this is correct. You can also reverse the order by using the Descending Order option but the Flat to Flat option will not work in that case. Refer to:Trade Activity Log: Reversing Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-16 20:35:11
[2018-11-16 19:57:28] |
You are correct. It showed that way because the Futures Month that I was using changed between the 14th and 15th. Anyway I discovered I can re-create that concept by selecting only the current days trades to show. That way my running cumulative totals will be for today only. Thanks,
