Date/Time: Thu, 23 Jan 2025 05:10:45 +0000
TPO Chart Date
View Count: 806
[2018-11-16 14:36:37] |
User180126 - Posts: 12 |
I was informed about a TPO chart that is giving today's date as Saturday 11/16 My example is displaying today as Thursday 11/16. Can you advise what setting this needs to be. Attached ate my chart settings.
TPOESZ8.png / V - Attached On 2018-11-16 14:35:55 UTC - Size: 64.64 KB - 305 views CHARTTPOESZ8.png / V - Attached On 2018-11-16 14:36:03 UTC - Size: 78.77 KB - 339 views |
[2018-11-16 18:02:58] |
Make sure the computers clock and the time zone setting is correct. Refer to: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating After that, re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-16 18:34:20
