Date/Time: Thu, 23 Jan 2025 05:10:02 +0000
Processing efficiency question
View Count: 605
[2018-11-16 13:51:53] |
RonW - Posts: 105 |
Generally speaking, assume I have a chart with a lot of data, say tick data going back years. Assume I want to run a LOT of studies on that chart. However many qualifies as a lot. From a processing efficiency/speed point of view, does it make sense to have several copies of the chart, each with a portion of the studies? Or is that worse because I would be loading all that tick data multiple times? |
[2018-11-16 17:58:31] |
Just one chart is enough.
