Date/Time: Thu, 23 Jan 2025 05:17:03 +0000
Main Price Graph Study Tool Values
View Count: 1368
[2018-11-16 12:33:24] |
User921987 - Posts: 238 |
Is it possible to show Study values in the Tool Values Window when the Study is set as a Main Price Graph ?
[2018-11-17 10:39:41] |
Yes of course. If there is any issue, refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails67.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-17 11:11:40] |
The problem is if my study is set as a Main Price Graph I am not able to view my study values in the Tool Values Winodow. The link you gave me does not give a help. The "Display Main Graph Values in Values Windows" in the "Chart->Chart Settings->Advanced Settings" is Checked. If I uncheck the study (not a main price graph) then I'm able to see the values.
Date Time Of Last Edit: 2018-11-17 11:15:34
[2018-11-17 22:13:48] |
Does not make sense why there would be an issue. And the documentation is very relevant to this. It explains all the settings which can cause the values of a study to be hidden from the Chart Values Windows. The Chart Settings are not relevant because you are referring to a study. Once again here is the relevant documentation and you need to make the changes on the study itself and not through the Chart Settings: http://www.sierrachart.com/index.php?page=doc/helpdetails67.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-17 23:35:35
[2018-11-18 09:24:47] |
Now I got it. The checkbox settings in the Chart->Chart Settings->Advanced Settings->Settings window are referring to subgraph indexes for example in my study I don't have a "Volume" subgraph but my 5th subgraph is called "Speed" and I can enable my Speed subgraph by checking the Volume box. So it's a good practice to check all those boxes in the settings window when your study is displayed as a main graph. Thank you. Date Time Of Last Edit: 2018-11-18 11:15:35
