Date/Time: Sun, 24 Nov 2024 12:15:30 +0000
How to add other study collection to my current studycollection
View Count: 1962
[2013-11-04 13:16:41] |
bwasi - Posts: 34 |
i have 10 studies in my study collection. I want to add macdcrossing study collection into my study collection as no 11 studies. How to add it ?..see 2 attachemnt
ScreenHunter_46 Monday, November 04, 2013 21.11.gif / V - Attached On 2013-11-04 13:13:00 UTC - Size: 30.85 KB - 490 views Attachment Deleted. MACD Crossing.StdyCollct - Attached On 2013-11-04 13:16:19 UTC - Size: 15.72 KB - 626 views |
[2013-11-04 15:34:58] |
Sierra Chart - Max - Posts: 5730 |
If you would like to add a new study to the study collection, all you need to do is add the study you want and save the study collection again. Refer for the study collection documentation here: http://www.sierrachart.com/index.php?l=doc/doc_StudyCollections.html#Modify To add a study, refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingStudiestoaChart Sierra Chart Support Date Time Of Last Edit: 2013-11-04 15:36:21
[2013-11-04 17:54:59] |
You can also set the Study Collection that you want to add to another Study Collection to Prompt To Remove Existing Studies and then you can apply it without removing the existing studies from the chart. This is explained on this page: http://www.sierrachart.com/index.php?l=doc/doc_StudyCollections.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
