Date/Time: Thu, 23 Jan 2025 04:58:18 +0000
Look Back Period for High/Low period or Initial Balance
View Count: 1085
[2018-11-16 10:20:00] |
User93757 - Posts: 61 |
Hi, Just a simple request if you have time. Would it be possible to add a look back period for High/Low Period or Initial Balance Studies. This way, you can get an over night balance if you run RTH and ETH on your charts. I'm sure there would be a lot of other uses. To be clear, i'm just looking to draw a line from the previous session on current chart. Both sessions are on the chart. I realize that you can do this with an overlay... But just saying, there may be a lot of other uses for this feature. Thank you, |
[2018-11-16 17:50:40] |
Use this study: Previous/Period OHLC-Variable Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
