Date/Time: Thu, 23 Jan 2025 05:17:53 +0000
[Programming Help] - DOM on chart
View Count: 588
[2018-11-16 09:54:32] |
Scalper T-Rex - Posts: 2 |
Hello to the team of Sierra chart. First, thanks for your platform that is just exeptionnel, the most optimized and the infinite possibility of modification. However, I wish like other traders / researchers, the DOM on graph which is by default on the window 1 of the chartbook can not be moved, is it possible to be able to change that? To be more clear we want to be able to midify also the placement of DOM on graph to know if it is possible to place it in another window because, we have chartbooks with the main graph on the window number 2, thus the DOM on graph should follow the main graph, can you update this possibility. I would be extremely grateful. Thank you again for what you did and what you did. Sincerely, Pasquier Thomas. |
bandicam 2018-11-16 10-53-35-090.jpg / V - Attached On 2018-11-16 09:53:48 UTC - Size: 17.02 KB - 236 views Attachment Deleted. |
