Date/Time: Thu, 23 Jan 2025 05:15:18 +0000
Trade Activity Log - Copy Selection Error
View Count: 627
[2018-11-16 07:58:55] |
Marmany - Posts: 307 |
On Trades tab highlight last entry row, hit Edit / Copy Selection and paste to Excel works as expected apart from symbol column is blank (header is OK). Highlight several rows and they do not all copy over. Highlight some other rows and only the previous highlighted rows are copied. Need to close the log to clear the paste board. Currently on v1842 but same issue with 1837. Prior to that Copy Selection worked OK. Edit / Copy All works perfectly in all versions. Please look into this. |
[2018-11-16 17:47:00] |
We are going to look into this.
