Date/Time: Thu, 23 Jan 2025 09:50:28 +0000
[User Discussion] - Quote Board and Study Summary
View Count: 1157
[2018-11-16 03:18:42] |
User606491 - Posts: 164 |
Hello, Two important requests: Can you add chart linking functionality to the Study Summary (as already exists on the Quote Board)? Can you make the Comment fields on the Study Summary editable (as is the case on the Quote Board)? My screen space is limited, especially when traveling and using a laptop. Having both the QB and SS windows open consume valuable screen real estate. As always, thank you. |
[2018-11-18 19:04:37] |
Any update here would be greatly appreciated. Thank you. |
[2018-11-19 21:18:52] |
Refer to: Meaning of User Discussion or Programming Help Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
