Date/Time: Thu, 23 Jan 2025 05:08:03 +0000
Conditional coloring of Study Subgraphs Reference Fill Area
View Count: 1861
[2018-11-15 22:03:42] |
jaxscott - Posts: 57 |
When I have my 5 Moving Averages all "stacked" I'd like to color the fill area between the MA lines. I know how to use the Study Subgraphs Reference to accomplish a fill, but I'm wondering if there is a way to only color the fill if my alert criteria are met (i.e. when 10 is above the 20 which is above the 50, etc.)
[2018-11-15 23:46:47] |
John - SC Support - Posts: 37420 |
Yes, this can be done. The general idea is to use 2 Color Bar Based on Alert Condition studies that reference a Moving Average Subgraph each. You would put your criteria into the Alert formula for each of these Color Bar Based on Alert Condition. Then, you need to add a (or modify your existing) Study Subgraphs Reference to reference the Color Bar Based on Alert Condition studies. We have attached a Study Collection using 2 moving averages to help get you started. You will find the information on how to use the Study Collection here: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
FillBetweenMovingAveragesWhenCriteriaMet.StdyCollct - Attached On 2018-11-15 22:58:38 UTC - Size: 55.91 KB - 433 views |
