Date/Time: Thu, 23 Jan 2025 04:57:24 +0000
line tool config can not be changed
View Count: 1344
[2018-11-15 20:25:32] |
User363047 - Posts: 2 |
Can not get the line tool config to change, either at global settings, or the tools tab or the tool button. It always stays the same color, size, direction. It bounces back to the former setting after I "save", "load", "apply" and 'Ok",, what's up. just down loaded the latest version. thanks |
[2018-11-16 18:53:00] |
The newer versions of Sierra Chart have made some changes to how the Configurations are loaded and saved. Please review the documentation here for how it now works: Chart Drawing Tools: Using Multiple Drawing Tool Configurations If you continue to have problems, please include a few screenshots so we can better understand where exactly you are having the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
