Date/Time: Thu, 23 Jan 2025 05:02:58 +0000
Ver 1841 - Compact Tool Value Window
View Count: 605
[2018-11-15 18:37:23]
NRGTrader - Posts: 351
Is there a method to fix the compact tool values window at the same location on all charts?
[2018-11-15 20:35:24]
Possibly ignore - I believe I located the answer. If correct, no reply necessary.
- Global Settings >> Tool Settings >> Save Compact Tool Values (CTV) Window Position for Each Chart
->>> UNCHECK to save global, correct?
